AutoCAD Forum
polylıne settıngs are broken
3 REPLIES 3
bereketmahmutcan
333 Views, 3 Replies
Polylıne settıngs are broken . when ı choose and draw polylıne, looks lıke photo of the add to down.
How can I normal settıngs ? I want draw polylıne lıke lıne.
3 REPLIES 3
cadffm
in reply to: bereketmahmutcan
you have polylines with width >0
and you can see the filling if fillmode is set to 1
AND your view is perpendicular!
If fillmode is 0 or view isn't perpendicular to the polyline plane = no filling visible.
Short test:
Fillmode=1
Plan current
draw a new polyline ...
Or for existing polylines:
UCS object <pick polyline>
Plan current
Sebastian
@bereketmahmutcan wrote:
.... I want draw polylıne lıke lıne.
If by that you mean without width, in your next PLINE command, after giving it the start point, choose the Width option and set that to 0.  Or do what that does without being in a PLINE command -- set the PLINEWID System Variable to 0.
Kent Cooper, AIA
pendean
we have no idea what it is you are asking: try again?
Post in your native language too if that helps.
AutoCAD Inside the Factory
