Polyline deleting after exploding in AutoCAD 2018
MikhailovAndrey
Advisor Advisor
Message 1 of 35
MikhailovAndrey
Hello, friends!
I try to explode any polyline (or rectangle, polygon, donut, etc.), but it's not exploding to different parts, it's just erased.
Is this a bug, or I just miss something?
AutoCAD 2018.0.2
Mikhailov Andrey
Mechanical & Electronics engineer
Blog
Replies (34)
Message 2 of 35
john.vellek
HI @MikhailovAndrey
I have not seen this before. Can you attach a sample drawing that shows this behavior? Is it that perhaps the rectangle is on a different layer?  Very strange - I would like to take a look for you.
John Vellek
Message 3 of 35
imadHabash
it's weird thing .... would you please show us a screencast to recognize your issue?
Imad Habash
Message 4 of 35
MikhailovAndrey
I record a screencast
Mikhailov Andrey
Blog
Message 5 of 35
chriscowgill7373
I'm not able to reproduce this on my system and I confirmed I'm on 2018.0.2.  I've tried it in 2 different versions, my NFR (OOTB) as well as my commercial copy and everything works as expected.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 6 of 35
pendean
Community Legend
Community Legend
Post a DWG file with this problem, figure out a way to point to one of these objects so we can all try them ourselves.
Message 7 of 35
Alfred.NESWADBA
what happens when you run command _REGEN after _EXPLODE?
Does it help if your disable hardware acceleration? (command _GRAPHICSCONFIG)
Are you running that test in a new drawing based on an original AutoCAD template?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 8 of 35
MikhailovAndrey
I create polyline and try to explode it in this file. Polyline is deleted after that
Mikhailov Andrey
Blog
Message 9 of 35
MikhailovAndrey
Hi!
  1. _REGEN - all the same
  2. If I disable hardware acceleration, I take the same result
  3. Yes, I try to create new drawings on original acadiso.dwt & acad.dwt.
Mikhailov Andrey
Blog
Message 10 of 35
Alfred.NESWADBA
your drawing does not contain a polyline ...
When I create a polyline in your drawing and _EXPLODE it, I get it converted to lines, as expected.
- alfred -
Alfred NESWADBA
Message 11 of 35
ВeekeeCZ
Try the .EXPLODE command, note the dot.
Message 12 of 35
Emmsleys
Hello @MikhailovAndrey
Where you able to try the suggestions, made by Alfred.NESWADBA and BeekeeCZ
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Sarah Emmsley
Technical Support Specialist
Message 13 of 35
MikhailovAndrey
Of course there is no pline. It's deleted
Mikhailov Andrey
Blog
Message 14 of 35
MikhailovAndrey
All the same with .explode
Mikhailov Andrey
Blog
Message 15 of 35
Vinayv4v
What happens if you try command XPLODE
Cheers,
Vinay Vijayakumaran
Message 16 of 35
ennujozlagam
downloaded your file and replicate your problem and works fine with the polyline is not deleted when explode. try to repair your autocad it could be some files are corrupted. thanks
Message 17 of 35
The same.
ACad 2018.0.1
Message 18 of 35
john.vellek
Hi @Anonymous,
Does your AutoCAD have any plugins or customization? If you create a brand new (administrator) user on your computer and then launch AutoCAD does the behavior continue?  Is it possible to attach a sample file with the pline that disappears once exploded?
More importantly, please update your AutoCAD today to the latest version. (.02). If you don't do this today your AutoCAD will fail to run tomorrow. For more information, please see this post.
John Vellek
Message 19 of 35
Kloshar13
I have this bug in any file i open or create.
AutoCad 2018.0.2
Message 20 of 35
MikhailovAndrey
I solve it. It's not a bug!
The problem occurs because of the installed SPDS Extension beta for AutoCAD 2018 (SPDS Extension from Autodesk is the app, that provides you to create and annotate your drawings in Russian standards).
Just uninstall it and all be OK!
Mikhailov Andrey
Blog
