when placing an arc into a polyline there is a distinct gap at the end point of the arc and line. How do I overcome this display error, see snapshot below, regards Ivan
Solved by user181. Go to Solution.
We need to know what is the procedure you follow to place the arc ? also it's good to attache here a CAD dwg sample for testing ?
Imad Habash
Use the GRAPHICSCONFIG command and change the 2D Display settings from Advanced Mode to Intermediate Mode or even Basic Mode.
