AutoCAD Forum
Polyline / arc display
3 REPLIES 3
ibarnardHMM2J
339 Views, 3 Replies
when placing an arc into a polyline there is a distinct gap at the end point of the arc and line. How do I overcome this display error, see snapshot below, regards Ivan
3 REPLIES 3
imadHabash
in reply to: ibarnardHMM2J
We need to know what is the procedure you follow to place the arc ? also it's good to attache here a CAD dwg sample for testing ?
Imad Habash
user181
Use the GRAPHICSCONFIG command and change the 2D Display settings from Advanced Mode to Intermediate Mode or even Basic Mode.
pendean
@ibarnardHMM2J Does REGENALL command when you are zoomed in that close solve the display issue? If not, the person that drew those simply 'missed'. You'll need to share that DWG here for others to rview.
Forma Design Contest
AutoCAD Beta
