Hi , Im using Autocad 2020 in Windows 10 1909
i cannot print directly from autocad to my HP Designjet 1055CM , an unknown error showed up then my plotting process was cancelled (it said "the parameter is incorrect")
If i convert the .DWG file to PDF , then i can print it from adobe reader.
but is there any way i can print it directly without converting it to PDF?
any help and suggestion would help me by a lot.
Thank You
mr.pendean , i believe that i am using HP designjet1000 series driver , do you have any recommendation on HP designjet driver? ofc i will also try to find a better more compatible driver , but it seems my search is hitting rock bottom
oh yea , sorry , my bad , by the way i have tried the older hp750 driver , i even tried newer HP4000ps series , and it didnt work , can you explain more to me what is installing driver with PLOTTINGMANAGER in autocad options? i think i want to learn about it
