Plotstyles (STB): Change default plotstyle to "ByLayer"
cwr001
cwr001
I'm a bit confused here and hope that someone can help me out. I'm using Civil3d 2025 but that's more of an Autocad-question:
I'm creating a new template with STB-plotstyles. The styletable is established and it works well.
I've created three layers and assigned plotstyles to them:
So far so good - but when I now set "MyLayer1" active and draw e.g. a polyline, the plotstyle is set to "Normal":
I thought that this would just be a setting in the options, but there the default is already set to "ByLayer":
Using an old template, the behaviour is as expected: When I draw an object on a layer, the plotstyle is set to "ByLayer":
So I'm guessing there's a setting somewhere that I'm not aware of. Any help would be very appreciated!
tl&dr:
When I draw an object on a layer, I want the default plotstyle to be "ByLayer" instead of "Normal".
cwr001
Okay, I'm an idiot - in the plotstyle-tab (settings, when nothing is selected), the plotstyle was set to "Normal".
Once I've changed that to "ByLayer", everything works normally.
