Hi There,
Screencast below..
I am trying to create a hole in a solid that does not go all the way though, ie the part is 22mm thick and I want an 18mm hole in the object.
Firstly I drew the shape of the object, and then the holes in 2d lines, and then extruded to 22mm.
I have successfully used presspull to create a number of recesses, so then I moved onto the holes.
I selected presspull, selected inside the circle, moved the extrusion upwards so I could see it, then entered -18 and hit enter.
This worked perfectly, just like the previous recesses I created.
However, I cannot repeat this on any of the other circles no matter what I try.
Either the circle disappears for some reason or nothing changes.
Was it wrong to create the holes whilst still in 2d?
I have no idea why this worked the first time and now I cannot replicate it.
Thanks, Shane.
