Plot Settings
Plot Settings
foste312
Plot Settings
foste312
I keep getting this message every time I try to plot something.
I've opened up my dwt file and typed in opitions selecting the two different printer/pdf to plot to, making sure they were the same.
How do I get it to auto select and print to adobe, so I don't have to slick esc every time this message (first pic) pops up?
cadffm
Plotter setting is part of pagesetups,
there is no setting to do what you trying!
Sebastian
cadffm
Command Plot
Change Printer and Papersize to your needs.
Press [apply to layout].
Since now, no message in this layout anymore.
Sebastian
pendean
Community Legend
Community Legend
In AutoCAD, in every single DWG file, every tab has it's own settings that are imbedded. A system level setting is always ignored.
To do what you want sort-of in a way, you need to make some concerted effort is creating a template file, creating named pagesetup, then using PSETUPIN command to bring in to existing files.
Are you up for doing all of that?
paullimapa
Would that message disappear if you run Options > Plot and Publish tab select Hide System Printers
Paul Li
IT Specialist
@The Office
foste312
CADffm
I've tried that and it does not save the layout, I'm working in model space with a boundary to select.
Paulli
Checked and that settings already selected.
cadffm
>>"I've opened up my dwt file"
But your pictures shows you are in a .DWG file, not in your .dwt.
.DWT file: Template for new files only. New DWG files, based on this template, will show the same settings as your .dwt.
.DWG file: You see the last saved settings
There is no feature to change the printer in pagesetups by themself.
Would you please confirm again:
Take your sample file (a DWG),
Command Plot
<Q: The message appears?>
Since now, no message in this file, in this layout anymore.
<Q: Right, or wrong?>
Sebastian
