Data extraction fail
MATEO_PROANO_ALBUJA
Message 1 of 13
MATEO_PROANO_ALBUJA
This message keeps popping up when trying to use the dataextractioCaptura de pantalla 2022-12-07 114426.pngn command
Replies (12)
Message 2 of 13
paullimapa
Looks like your AutoCAD has a failed installation. First make sure you have installed all updates. Enter About and show us what version you have installed
Paul Li
IT Specialist
@The Office
Message 3 of 13
MATEO_PROANO_ALBUJA
Thank you for your responde!
This is the version installed
Message 4 of 13
MATEO_PROANO_ALBUJA
Thank you
Message 5 of 13
paullimapa
That is the latest version
perhaps try resetting to AutoCAD defaults
But if that fails may have to uninstall and do a new install
Paul Li
IT Specialist
@The Office
Message 6 of 13
MATEO_PROANO_ALBUJA
OK let me see if the solution works!
Thank you
Message 7 of 13
MATEO_PROANO_ALBUJA
My friend,
The solution did not work. I reinstalled de program and updated it but the same error keeps popping
Message 8 of 13
MATEO_PROANO_ALBUJA
My friend,
I tried everything you suggested but the error keeps popping
Message 9 of 13
paullimapa
If uninstalling and then reinstalling and applying all the updates still don’t work then it’s tome to contact your reseller or Autodesk support directly to help troubleshoot this problem.  Of course if you have another computer then that would be another place to start.
Paul Li
IT Specialist
@The Office
Message 10 of 13
cadffm
Message 11 of 13
MATEO_PROANO_ALBUJA
now this error is happening any help?
Message 12 of 13
paullimapa
What Windows OS are you running on?
Do you have another computer to install AutoCAD 2023?
Does the Dataextract error occur on all drawings or only on a specific one?
Try adding /safemode switch to the AutoCAD shortcut you are using to launch AutoCAD and then see if the error occurs.
Paul Li
IT Specialist
@The Office
Message 13 of 13
MATEO_PROANO_ALBUJA
Hello Paul,
I am using windows 10. But it doesn't work in windows 11 either.
The problema is happening in every drawing
Ill check in the safemode
Thankyou
