hello. ive never had this issue before, i just got a new laptop so i had to re-download autocad. ive tried to save a pdf in autocad to later import into photoshop. as ive tried to save the file, when im plotting the preview just shows up blank. ive put the paper size in, put windows in the plot area as i need it to scale, ive centred the plot and in the plot scale section ive put 1:20 the same as my drawing, and the plot transparency is off. ive read multiple suggestions but nothings working! someone help me asap please!
Solved by pendean. Go to Solution.
Okay, you say the preview is blank, but if you complete the print to PDF, is the resulting PDF okay?
oh my goodness, the drawing was white! cant believe it was that simple. hours of stress for no reason! i had a feeling i should've changed it too! thank you so much.
if you are printing a layout go to layout manager and re-chose the same paper size then try to print again
it worked for me
