Plot preview different of pdf
I have a Ctb that I've been using from a long time, but now The plot is different from the preview and I don´t know how to fix it..!
pendean
Community Legend
Community Legend
Different means what to the rest of us?
Why not show us too, post images etc. while you are at it.
Thx
natasha.l
Hello @Anonymous,
In some cases ctb files will not function in all versions especially a ctb file created in a later version, being used in a current version.
Try renaming the ctb file or try any of the other default ctb files to test, if the others function then its your custom ctb file.
You could re-create it in your current version of AutoCAD.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
There are both plots, the colors seem over saturated. i tried making a new ctb file but it didn´t work...
You can see the difference here...
conner717
What printer are you using to create the PDF with? Adobe, Bluebeam, or DWG to PDF
I´m using Dwg to PDF.pc3 but even if I change it, I doesn't solve the problem
