Plot PDF to native folder path of document
alfaizmusa098
Observer Observer
Message 1 of 11
alfaizmusa098
Observer
Observer
I am using AutoCAD 2023, and when I plot any document to PDF, it saves to the previous folder path or the default folder path. I want it to save to the native folder path of the document when I plot any document to PDF.
Help me with this issue. Thanks
Replies (10)
Message 2 of 11
Ed__Jobe
When you send the plot to pdf, it uses the pdf printer driver to save the file. So AutoCAD has no control over where the file is saved to. If you are using the DWG TO PDF. pc3 printer driver, it's just using standard Windows behavior and remembering the last folder used. If you plot using the PUBLISH command, you can specify the output folder.
Ed
How to post your code.
Message 3 of 11
Valentin_CAD
@alfaizmusa098 ,
@alfaizmusa098 wrote:
... PDF, it saves to the previous folder path or the default folder path. I want it to save to the native folder ...
Try this suggestion:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 11
Ed__Jobe
Hi @Valentin_CAD I don't think that's what he wants. If he plots a dwg, it should save the pdf in the same folder as the dwg location. As the dwg location changes, the plot location should change too. However, the DWG TO PDF printer just uses the last location that was plotted to.
@alfaizmusa098 If you switch to Bluebeam, their driver allows you to set the default path to the source folder.
Ed
Message 5 of 11
pendean
Community Legend
Community Legend
@alfaizmusa098 @Ed__Jobe @Valentin_CAD Once you change it you can never go back, Autodesk has been aware of this limitation for decades, you're options are to use 3rd party PDF drivers instead
Message 6 of 11
alfaizmusa098
Observer
Observer
Thanks for replies but none of this solve my issue. I understand that this is configuration of "DWG TO PDF" to save pdf to previous saved path. Is there any way I can change the configuration of this plotter to save pdf on its native path?
Message 7 of 11
Valentin_CAD
@alfaizmusa098 ,
Try this:
Emilio Valentin
Message 8 of 11
alfaizmusa098
Observer
Observer
Thanks, but not working, still cad opens up the Previous saved path.
Seems like, plotter configuration needs to be changed.
Im using DWG TO PDF plotter.
Message 9 of 11
cadffm
>>"Thanks for replies but none of this solve my issue"
Right
>>"I understand that this is configuration of "DWG TO PDF" to save pdf to previous saved path."
Okay
>>"Is there any way I can change the configuration of this plotter to save pdf on its native path?"
? You wrote "I understand that ".. and as you read it before, there is no way to do it for the native PDF drivers
and the workaround is: Use another PDF driver for PLOT, or use PUBLISH command
DWG to PDF.pc3 and AutoCAD PDF (...).pc3 => No
other installed PDF printers on your PC => Depending on the settings of your win pdf driver
Sebastian
Message 10 of 11
Ed__Jobe
I already told you that you CAN"T change DWG TO PDF. You need to find another driver that allows you to change it's plot path. One that I use is Bluebeam pdf system printer driver. It comes with a purchase of Bluebeam Revu.
Ed
Message 11 of 11
pendean
Community Legend
Community Legend
@alfaizmusa098 You do appear to be ignoring what everyone is saying
Autodesk is the only entity that can fix what you want and they have not done so in 20+years now. So you need to do something else, see the other advice from everyone asking you to use a 3rd party PDF driver.
