Plot a series of drawings using array or something.
d.shrestha977
Message 1 of 10
d.shrestha977
I have to plot multiple drawings in the same model space, containing multiple frames with their own unique titles and drawings. The frames are composed as a rectangular array. I could plot using window selection, but there are hundreds of frames. So instead I am here to find help finish the job quicker.
http://www.cadforum.cz/cadforum_en/plotting-a-series-of-drawing-frames-composed-in-a-dwg-drawing-tip...
I want exactly what the link says it does. I downloaded the program, but it's not working.
When I try to plot, CAD responds with, " Unknown command, "PLOTDWGARR". Press F1 for help".
When I try to make layouts using the program, it says to "create the template first", even though I've already created one.
Thanks in advance.
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Your found Customization wants to create a layout for each frame, but you must have a Layout already defined/set up in a template file somewhere.
Do you ever plot from layouts at all?
Message 3 of 10
maratovich
There are other programs for printing from the model, you need to try different.
Attach an example of your .dwg file for verification.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 4 of 10
d.shrestha977
yes I created the layout template with the given name, still I was flashed with the same response of creating the template first.
And yes again, I often use layouts to plot my work.
Message 5 of 10
d.shrestha977
Please tell me what other programs can be used that meets my need.
Message 6 of 10
maratovich
You can try this:
Revers - Automatic batch printing a multiple format (rectangles, frames) of model space
https://www.kdmsoft.net/revers.html
If you attach your sample file, you can accurately answer.
www.kdmsoft.net
Message 7 of 10
d.shrestha977
I couldn't get the program to work. I didn't know where  to start with the software, but whatever I tried didn't seem to work. Is there any other solution to my problem.
I've attached a sample
Message 8 of 10
maratovich
Your file is very good.
No problems.
Look at the settings on the picture, and look for the search and print window.
Repeat these settings, perform a search and print.
www.kdmsoft.net
Message 9 of 10
d.shrestha977
I still can't get it done. I can't figure out what went wrong. I attached the snippets for you to find out the glitch. Please help me.
Message 10 of 10
maratovich
You need to set up a template.
Specify the size of your frames 84x59
Specify your printer and paper size.
L
www.kdmsoft.net
