Announcements
Is ther any way to change a name of a block?
danezeq
danezeq
Replies (11)
ValdisPriednieks
I do not know.
You can open the block for edit, then «save block as», give new name for block, then purge block with old name.
Alfred.NESWADBA
Command _RENAME
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
MikeKovacik4928
the rename command
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
danezeq
thank you all 🙂
Kent1Cooper
If you'd like to be able to do it by selecting a Block insertion, without  needing to know what its name is to use in the RENAME dialog box, check out RenameBlock.lsp with its RB command, available >>here<<.  This is especially handy when the Block is the result of using PASTEBLOCK and has a name like A$CFG5D32S.
Kent Cooper, AIA
MikeKovacik4928
Kent
That is really cool!
I will download and use it here at home, and introduce it at work as well.
I am going to introduce using of lisp at work as well,
and start a work AutoCAD Hints &Tips,
This will be AutoCAD Hint & Tip No 1
Mike
Kent1Cooper
@MikeKovacik4928 wrote:
I am going to introduce using of lisp at work as well, and start a work AutoCAD Hints &Tips, This will be AutoCAD Hint & Tip No 1
A closely-related suggestion for Tip No 2 -- PasteBlockWithName.lsp, available >>here<<, which prevents those wacky A$CFG5D32S Block names that result from PASTEBLOCK from getting into your drawing in the first place.  It does it by redefining the command  to require you to give a PASTEBLOCKed Block a meaningful name when you bring it in.  If that kind of wacky name is a major reason you want to have RenameBlock.lsp / RB on hand, this would eliminate the need for it in that situation [except for pre-existing wacky names], though RB is still useful, since it can also be used to change other-than-wacky names.
Kent Cooper, AIA
MikeKovacik4928
Kent
When you copy with base point a whacky named block from another drawing, and then paste it,  into a new drawing nothing changes.
However when you paste it as a block, as you say, it asks for a new name.
this however makes it into a nested block which when exploded becomes the same wacky name again.
It is a nice lisp routine, I will keep it and see if I can put it to use
I will put it as my AutoCAD Hint and Tip No 2, anyway
Mike
Kent1Cooper
True -- it doesn't "fix" a wackily-named Block if that's your source object.  It affects only the Block name within the current drawing of clipboard material brought in via PASTEBLOCK [everything on the clipboard collectively, whether that's one object or more], but not that of a Block object that already has a name, when brought in from another drawing that way -- that would just be an object that retains the properties it had in the source drawing, just as a Line would when included in the clipboard material.
To fix such a Block name when you bring it into the current drawing, you would need to use either ordinary PASTE rather than PASTEBLOCK, or the Design Center, followed by RB [or better yet, use RB on it in the source drawing first].
Kent Cooper, AIA
MikeKovacik4928
Thanks Kent
Noted, will bear that in mind.
Mike
Thats was easy thank you.
