AutoCAD Forum
Please help.. Some lines are plotted too light..
4 REPLIES 4
572 Views, 4 Replies
Have been trying to fix this for hours but still some lines are plotted too light.. Need help
4 REPLIES 4
adding some information:
have tried 'ma' command and put all lines into one layer, doesn't work.
it happens when dwg->pdf btw
pendean
That's your PDF viewer's display settings: zoom in a lot closer in the PDF viewer and you'll see they are all identical in reality.
Fix your default PDF viewer settings, if it's Adobe Acrobat/Reader, you want to go into Preferences in that application and uncheck SMOOTH LINE ART, ENHANCED THIN LINES, USE SMOOTH ZOOMING, and increase your RESOLUTION to a CUSTOM RESOLUTION setting of 400 picel/inch minimum.
in reply to: pendean
thank you very much!!!
AutoCAD Inside the Factory
