AutoCAD Forum
PLEASE HELP ME JOIN THESE OBJECTS+
10 REPLIES 10
Message 1 of 11
684 Views, 10 Replies
I can not join these red objects, I have tried so many ways...
I need this because I want to extrude it into 3D
Please help me soon
Thanks a lot!
Labels (1)
10 REPLIES 10
Message 2 of 11
vinodkl
Hi @Anonymous
The objects consist of self-intersecting lines that's why you are not able to extrude it. Try to explode all the elements and remove the self-intersecting lines and then join them. After that use the command "PRESSPULL" to create solid objects instead of "EXTRUDE" command 🙂
See attachment.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 11
in reply to: vinodkl
Hi @vinodkl
Can you teach me how to remove the self-intersecting lines...
Really appreciate your help!
Thank you
Message 4 of 11
Patchy
Co gi dau
Explode it, xong roi dung  REGION, then EXTRUDE
Message 5 of 11
in reply to: Patchy
Em vừa thử mà không được, giúp em được không ạ...
Message 6 of 11
Patchy
Sure, I'll try
Save it to version 2014 or earlier for me (I'm using 2014)
Let's see
Message 7 of 11
in reply to: Patchy
Autocad 2013
Message 8 of 11
Em vừa convert lại file bằng DWG Trueview
Message 9 of 11
Patchy
Use Snap to endpoints more often.
Message 10 of 11
in reply to: Patchy
Really love your enthusiastic support!
Big thanks!!!
Wish you all the best.
Message 11 of 11
Patchy
Come back if you need help ☺
AutoCAD Inside the Factory
