PLEASE HELP ME JOIN THESE OBJECTS+
This widget could not be displayed.
I can not join these red objects, I have tried so many ways...
I need this because I want to extrude it into 3D
Please help me soon
Thanks a lot!
Replies (10)
vinodkl
Hi @Anonymous
The objects consist of self-intersecting lines that's why you are not able to extrude it. Try to explode all the elements and remove the self-intersecting lines and then join them. After that use the command "PRESSPULL" to create solid objects instead of "EXTRUDE" command 🙂
See attachment.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi @vinodkl
Can you teach me how to remove the self-intersecting lines...
Really appreciate your help!
Thank you
Patchy
Co gi dau
Explode it, xong roi dung  REGION, then EXTRUDE
Em vừa thử mà không được, giúp em được không ạ...
Patchy
Sure, I'll try
Save it to version 2014 or earlier for me (I'm using 2014)
Let's see
Autocad 2013
Em vừa convert lại file bằng DWG Trueview
Patchy
Use Snap to endpoints more often.
Really love your enthusiastic support!
Big thanks!!!
Wish you all the best.
Patchy
Come back if you need help ☺
