pen widths not plotting
TECHSERVICES
Message 1 of 19
TECHSERVICES
our plot is not using our desired plot style (pen widths) for line work specifically... the screeening on the text seems to be coming in.. but all linework is the same, regardless of line type.... all linetypes coming in at same width....   where should i check first?
Replies (18)
Message 2 of 19
john.vellek
Hi @TECHSERVICES,
Can you eTransmit a sample file so I can take a look? Are you sure that the CTB file is getting applied?
Attach your etransmit so I can take a quick look for you.
John Vellek
Message 3 of 19
TECHSERVICES
U want a copy of the ctb? Or the cad dwg? If it's the cad .. .i'll give you 2.. the one that it seemed to be working with on wed. and the one that we can't get it right with.... Hint: we are also having some random linework show up as color on the plot preview...
Ken DePauw
[cid:[email protected]]
DRAFTSMAN
Operations
739 Sophia Street | Selkirk, MB R1A 2M1
tel 204-785-4937
www.myselkirk.ca
[cid:[email protected]][cid:[email protected]][cid:[email protected]]
Message 4 of 19
john.vellek
Hi @TECHSERVICES,
Yes, I want both and an eTransmit should bundle it up with fonts too.
John Vellek
Message 5 of 19
TECHSERVICES
as of the beginning of the week our 485 was plotting with correct line weight....the pitts dwg we can't get it to plot with proper lineweights at all.
Message 6 of 19
john.vellek
Hi @TECHSERVICES,
Yes, I do need to see your CTB file(s) as well.
John Vellek
Message 7 of 19
TECHSERVICES
our plotter is a kip 700 and it is black and white only...
Message 8 of 19
john.vellek
HI @TECHSERVICES,
Are you not using any plot styles then in your print jobs? If so, i see that acad.ctb is applied in your drawings. You should select None. If you do use plot styles have you modified the acad.ctb to reflect your lineweights? If so, I need to see the file please.
John Vellek
Message 9 of 19
TECHSERVICES
the ctb files ARE teh plot style options right?   i'm confused by your last email... sorry...
Message 10 of 19
john.vellek
Hi @TECHSERVICES,
I apologize. I certainly don't want to confuse you but just the opposite. The file I need is the the one that displays in the Plot STyle table in the plot windows.
John Vellek
Message 11 of 19
TECHSERVICES
 this config gets my linework to show up in PDF mode, but disappears in kip.
also, i have a kip series AND A kip series pc3
Message 12 of 19
TECHSERVICES
i can't attach my ctb here, NOR send it to you via email.
Message 13 of 19
john.vellek
Hi @TECHSERVICES,
Yes, that format is not allowed for upload without putting it in a ZIP file first (which is what the eTransmit does for you FYI).
Please give it another go so I can resolve this for you.
John Vellek
Message 14 of 19
john.vellek
HI @TECHSERVICES,
Are you able to zip up a CTB file for me? I would like to get your problem resolved.
John Vellek
Message 15 of 19
schurthing
@TECHSERVICES, You're plotting a layout tab, but you have "Scale Lineweights" checked in the "Plot Scale" section of the plot dialog, while you are not plotting at scale 1:1. Try turning off (uncheck) "Scale Lineweights" and see if that helps.
Stefanie
crazy autocad witch since release 8 😄
Message 16 of 19
TECHSERVICES
john, sorry about the tardiness.  was in field for a few.
Message 17 of 19
john.vellek
Hi @TECHSERVICES,
I applied the Selkirk CTB to your Pittsburg file and the lineweights came out fine. Originally, when I opened the Page Setup (11x17) it was looking for a non-present CTB. I used the Selkirk.CTB
I then tried it again using the COS CTB and while the results are different, I still saw the lineweights.
In your Pagesetups, it is not necessary to have the Plot Object Lineweights selected as they are being set by your CTB files.
John Vellek
Message 18 of 19
TECHSERVICES
i go into page set up.. uncheck the plot lineweights as suggested.. the preview seems good.  save, go into plot, and the preview does not give me line weights...   thanks for trying john, but something else is happening here... i can't see it.
Message 19 of 19
john.vellek
Hi @TECHSERVICES,
If you logon as a different (new) user to your computer is this still the same behavior? If so, you might try a Reset Settings to Default to see if this corrects the issue. You might experiment with the builtin PDF drivers to see if there is a different result with each one.
John Vellek
