PDFSHXTEXT command does not work in AUTOCAD 2017
Message 1 of 24
The PDFSHXTEXT comand does not work. It says Unknown command "PDFSHXTXT". And there is also no
Recognition SHX Text' icon in the panel.
already checked Product Updated, and there are no updates available for my Products at this time.
Replies (23)
Message 2 of 24
injineri
look in CUI, maybe you will found that command there and add it to ribbon
in my Autocad its under name "PDF SHX Recognition"
Message 3 of 24
chriscowgill7373
Where did you check to see if your product was up to date?  what version number does it show in the dialog that appears when you type ABOUT <enter> at the commandline?  it should be showing you are on 2017.1.2
If you are using the desktop app, it is known to be flaky on showing proper updates, I would look it up in your Autodesk account page product updates.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 4 of 24
ryan.bales
Autodesk Support
Autodesk Support
Definitely check your CUI. The CUI settings for that ribbon tab/panel should look like this:
Ryan Bales
Fusion 360 Product Support
Message 5 of 24
chriscowgill7373
@ryan.bales
but if typing the command PDFSHXTEXT returns unknown command, it isnt a CUI/Ribbon issue.
Message 6 of 24
ryan.bales
Autodesk Support
Autodesk Support
Perhaps, but since its not shown on the panel we need to check that first. Aside from that the command should be visible in the CUI menu, so opening the CUI should verify the panel, tab and command exist.
Ryan Bales
Message 7 of 24
checked, no 'PDF SHX Recognition'
Message 8 of 24
CUI of my Autocad shown.
Message 9 of 24
injineri
in your place probably I'd find and load someones working main cui file (acad.cuix) or reinstall autocad.
Message 10 of 24
Alfred.NESWADBA
@ryan.bales
Sorry, if trying to start the command by typing into the command-line and getting "unkown command" as result it does not make sense to do anything in the CUI. Even if the button for that command would exist it also would return "unknown command" ... so looking into the CUI does not help in any way.
I agree with @chriscowgill7373 most probably the update 2017.1.x was not installed, then the command would not exist.
So for the thread opener: start AutoCAD, start command _ABOUT and compare your version information with that screenshot:
If your version is lower than the one shown in the screenshot please start Autodesk Desktop App, make sure you are logged in, let it search a few minutes for updates and then install them.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 11 of 24
@Alfred.NESWADBA
I think you are right, my AutoCAD's version is much lower.
It is installed from intranet, not sure if it can be updated by individual.
Thanks for a lot. At least, I knew why I can't use that command.
Message 12 of 24
Alfred.NESWADBA
Why not, simply update it! As described start Autodesk Desktop App, login, wait a bit and then install ...
- alfred -
Alfred NESWADBA
Message 13 of 24
My AutoCAD is not  bought from my count. I installed it from our company's intranet. It might be some IT issue, not sure. Actually I dont know how to update it at this situation.
Message 14 of 24
Alfred.NESWADBA
Than you should have an account at Autodesk, either for login with Autodesk Desktop App or at the subscription center https://manage.autodesk.com ... also here you can download the update(s). At least your companies contract manager should have the access to that link.
- alfred -
Alfred NESWADBA
Message 15 of 24
kumaresan4ever
Kindly  if anything Possible in Created Lisp File??
Message 16 of 24
chriscowgill7373
If you dont have the 2017.1 update installed, there is no method to access the command.  a LISP routine isnt going to help.
Message 17 of 24
kumaresan4ever
ok thank your reply sir
Message 18 of 24
kumaresan4ever
i was using autocad 2018 , i can't convert to the text, some one text will came on text otherswise can't converted the text. Below the Screen shot image is shownCapture.PNG
Message 19 of 24
Alfred.NESWADBA
Have you seen the "Settings" option in the command-line within the command _PDFSHXTEXT?
This gives you a lot of options to define for how text can be recognized (or not):
- alfred -
Alfred NESWADBA
Message 20 of 24
kumaresan4ever
yes i am used seems to this text and all, i selected iso,romans,simply text options, but the result was not get it......
Kindly tell us how to solved this problem....
