...so now I have a referenced image file. AutoCad also created a file folder called "PDF Images" to store said .png.
My guess is that the PDF I'm trying to import is a document scanned into PDF, thus the imported image file.
Am I stuck with this, or is there a trick I don't know about?
Thanks!
Solved by vinodkl. Go to Solution.
Could be correct, at least the PDF has only raster/image content.
To get vectors in AutoCAD you'll need to have vectors in the PDF.
- alfred -
Your guess is correct the PDF is scanned document. You need to trace over the xrefed image and that's the only option left.
There are a few online converters that would convert the Raster image into dwg. You can give it a try, but I doubt you would be satisfied with the end result.
