AutoCAD Forum
PDFIMPORT is turning the pdf into a png...
3 REPLIES 3
TOMLANG7190
1441 Views, 3 Replies
...so now I have a referenced image file.  AutoCad also created a file folder called "PDF Images" to store said .png.
My guess is that the PDF I'm trying to import is a document scanned into PDF, thus the imported image file.
Am I stuck with this, or is there a trick I don't know about?
Thanks!
3 REPLIES 3
Could be correct, at least the PDF has only raster/image content.
To get vectors in AutoCAD you'll need to have vectors in the PDF.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
vinodkl
in reply to: TOMLANG7190
Your guess is correct the PDF is scanned document. You need to trace over the xrefed image and that's the only option left.
There are a few online converters that would convert the Raster image into dwg. You can give it a try, but I doubt you would be satisfied with the end result.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
TOMLANG7190
in reply to: vinodkl
That's what I figured.  Thanks for the quick answers!
Technology Administrators
