I have a client PDF which I need to use a base for a drawing. When importing the PDF the colours of the shading are modified. I've tried toggling on/ off the various setting but cannot get the PDF to display in CAD as it does in PDF.
I've done this previsouly with a different base and it worked fine, and I have no reason to believe that the PDFs are generated differently as they come from the same source.
I'm unable to upload the actual files due to client/ employer security but wondering if anyone may be able to shed some light given my description above (long shot, I know), and the image I'm sharing. You can see the difference between the preview and the actual impported PDF.
Thank you
