In the PDF options. I am trying to turn off the show results in viewer. But there is an invalid path warning coming up. See attached
How do I fix it
Morning Sir
Usually these settings once you change it would ask you to save it to a specific folder location.
You might of moved yours ? Maybe try and relocated the save path or redo it.
what happens when you adjust it in your paper space ?
hope this helps
Check this: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
This occurs with all PDF PC3 files. I have copied them from the downloaded Autocad 2021 file and still the same. I will try the reinstall option.
start command _OPTIONS and modify this path setting (change it to a different path, best a new folder on your local harddisk) ... better?
- alfred -
I have updated the plot to file location. And then tried to untick the Show results in viewer. But the error still occurs. as attached
I have attached the export file for all the settings. I these work, then is must the the Autocad install problem
