PDF options show results in viewer error
jason.larsenPF5AU
jason.larsenPF5AU
In the PDF options. I am trying to turn off the show results in viewer. But there is an invalid path warning coming up. See attached
How do I fix it
Replies (7)
coffeejeanpaul
Morning Sir
Usually these settings once you change it would ask you to save it to a specific folder location.
You might of moved yours ?  Maybe try and relocated the save path or redo it.
what happens when you adjust it in your paper space ?
hope this helps
vinodkl
Hi @jason.larsenPF5AU
Check this: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
jason.larsenPF5AU
This occurs with all PDF PC3 files. I have copied them from the downloaded Autocad 2021 file and still the same. I will try the reinstall option.
Alfred.NESWADBA
start command _OPTIONS and modify this path setting (change it to a different path, best a new folder on your local harddisk) ... better?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
jason.larsenPF5AU
I have updated the plot to file location. And then tried to untick the Show results in viewer. But the error still occurs. as attached
jason.larsenPF5AU
I have attached the export file for all the settings. I these work, then is must the the Autocad install problem
