PDF import
PDF import
cs2kplus
PDF import
cs2kplus
I am importing a pdf and the lines are thick. They are not plines. Thickness is default. Does anyone have a process to import pdfs and have the lines be normal lines?
chriscowgill7373
Would it be possible to share screenshots of what you are seeing,  as well as the settings you are using for your import?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
paullimapa
Perhaps you can share your pdf for others to try?
Paul Li
IT Specialist
@The Office
imadHabash
@cs2kplus
  • Would you please tell us what is the command that you use to import this pdf file?
  • LWDISPLAY system Variable = 0 ( Off ) then type Regen command. any changes?
Imad Habash
BhaskarMurari
@cs2kplus Please share your pdf here if possible.
obulesub
Hi, @cs2kplus,
I wanted to check in and see if you saw @BhaskarMurari @paullimapa @chriscowgill7373 follow up questions and requests or if you still needed assistance. If you found a solution to your question already, please share the details so that other community users can benefit from the information.
Or, did the information provided by @imadHabash help you and answer your question? If yes, please click on the "Accept Solution" button on the post that helped solve your issue. If not, please share any available screenshots or screen recordings so the community can assist you further.
Obulesu| Community Manager
