PDF Import into AutoCAD
Message 1 of 12
I have a 16 page PDF file that I would like to import into AutoCAD and have each page from the PDF come in as individual AutoCAD drawings/sheets.
Replies (11)
Message 2 of 12
cadffm
And what is your problem/question?
Import only one page to a file, each per each for every pdf page,
or import all in one file.
Creating Layouts for your drawing, thats your part and not part of the PdfImport-Function.
What is your problem or question now?
Sebastian
Message 3 of 12
So each page of the PDF have to be imported separately?
Message 4 of 12
john.vellek
Hi @richard.postak,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
If you want to bring all the sheets from your PDF at once, use PDFATTACH. Then once the pages are in your drawing you can use PDFIMPORT to convert each sheet to AutoCAD geometry if they are vector-based.
John Vellek
Message 5 of 12
cadffm
@Anonymous
Yes, separatly
john.vellek screencast is a nice workaround for the half work.
Another solution is programming, here a simple(dirty) snipped for testing:
(defun c:PDFIMPORT+ (/ file n c d)
(and
(setq file (getfiled "PDF for Import" "" "pdf" 8))
(setq c (getint "\nHow many pages from 1 to ?: "))
(setq d (getreal "\nDistance for inserting multiple pages (X-Axis): "))
(setq n 0)
(repeat c (command "_.-PDFIMPORT" "" file (1+ n) "_non" (list (* n d) 0 0) 1 0)(setq n (1+ n)))
(princ)
Sebastian
Message 6 of 12
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Sebastian's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 7 of 12
Works like magic 🙂 Thanks!
Message 8 of 12
maratovich
For those who find it difficult to use Lisp:
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 9 of 12
S_S_SS
Message 10 of 12
cadffm
Message 11 of 12
S_S_SS
Message 12 of 12
maratovich
@S_S_SS  написал (-а):
  can this lisp get number of pages automatically and don't ask me for it ?
and i want to get lisp for more pdf files at one time can i get that ??
Use this - AutoImportCAD
www.kdmsoft.net
