PC config for Autocad, MEP, Revit
injineri
injineri
Hello community, could anyone advise affordable and normal Processor, Motherboard and Graphic card for Autocad, Autocad mep and Revit programs for working with HVAC system designing in 3D? My budget for them are max 1000$ 😞
braudpat
Hello
The fastest Core i5/i7 you can !
With a basic speed > 3.4 Ghz
16 Gb (maybe more later depending on the size of your 3D models ?!)
NVidia Graphic card:
GTX 1060 / 1070
Quadro K1200 / 2X00 Series
Fast SATA disk (500 Gb minimum)
Or better SSD...
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
injineri
thats a nice configuration but expensive for me right now. how about this?
mother: GA-Z270P-D3 1.0
video: Asus STRIX-GTX1050TI PCI Express 4GB ,DVI*2,HDMI,DP,4G,D5
CPU: Intel/ Core I5 -7400 (3.0 GHZ 6MB LGA1151 )TRAY
RAM: 2x Crucial 8 GB, DDR4, 288-pin DIMM, 2400 MHz, Memory voltage 1.2 V, ECC No
HDD: SATA/ 3.5"/ 1TB/ Toshiba DT01ACA100 7200rpm 32MB 6GB/s
SSD: Kingston A400 SATA 3 2.5 Solid State Drive SA400S37/240GB
braudpat
Hello from France
For me the SSD is not the Master Key of the PC !
Every morning with my Coffee Mug, I WAIT
Launch Windows: 2 mn
Launch ACAD or REVIT: 1 mn
No problem...
So maybe remove the SSD ?!
1) And try to switch to a faster i5...
2) And try to switch to a 1060 3 Gb...
Regards, Patrice
Patrice BRAUD
