Hello and thank you for taking the time to help me out with this. I am currently trying to combine a bunch of blocks together to make a single configuration. These blocks are pretty simple, however they do have attributes attached to each one of them. I then make a configuration out of all them and save the block. However I notice that when going through the configurations some parts of the other blocks will bleed through (even though they should be invisible). I will try to attach some photos for better understanding. Any insight on why this is happening and what I can do to fix it will be much appreciated.
Solved by mgarcesUX9HW. Go to Solution.
hi just make sure the object visibilty is hide from other state which you dont want them to appear, i usually select that object right click and make the visibilty hide for all state and select it again and make it show for current state only. make sure you toggle the visibilty mode to see that object
