XREF Transparency Not Plotting
chadclark
chadclark
I have tried all possible solutions I have found on the forums and searching online. Please help! I can not get my xref transparency to print DWG to PDF?
Valentin_CAD
Hello chadclark,
Please attach the "2021-04-27-A-101-OVERALL-L05.dwg" reference file.
Have you consider these solutions?
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
chadclark
I actually found a work around just like I do everything in AutoCAD. I changed all my viewport colors and line weights in the layer settings as well as transparency viewport settings. This got me the final outcome I was looking for. Thanks for the suggestions.
chadclark
So I thought that was a solution but still getting the samething. Everything is coming in as the same line weight and darkness no matter what my screen shows and the settings I choose.
Valentin_CAD
Check these possible solutions:
Lineweights and linetypes do not plot or publish correctly from AutoCAD
Also, try resetting your Layer Override
Emilio Valentin
chadclark
Thank you, I didn't reset the xref overrides, but I was able to change the properties to what I wanted in that area! It the plotted correctly to my PDF. THANK YOU!!!!!
