Hello everybody.
In AutoCAD 2015 I made a small parametric drawing containing geometric and dimensional constraints. If I place the cursor on the object to which I have applied the constraints, a small marker appears.
I would like to ask you: is it possible to hide the mark?
Bye, thank you very much.
Sorry, you cannot hide the "constraint" cursor badge. There are few cursor badges such as the "constraint" and "annotation" which won't be turned off even when the system variable "CURSORBADGE" is set to "1" 🙂
May I ask why you are trying to hide that cursor badge?
Hi.
I would like to hide it because I am building a small application in VB.NET where a user can modify the geometric dimensions of a parametric block through a form.
