Paragraph Settings
Paragraph Settings
omorah
Paragraph Settings
omorah
Can paragraph settings (MTEXT: Tabs, Indents, Spacing, etc) be transferred from one drawing to another?
Thanks.
coffeejeanpaul
I think yes if you copy that text. Might change if the text style is setup differently
omorah
You made a good point, thanks for your reply.
However, if I already have an MText of three columned General Notes, but would like to match it to an MText in another drawing. Don't think I can import from another drawing and Match Properties. Wish an MText settings can be named.
coffeejeanpaul
Maybe I miss understand your question but you can indeed create text styles for mtext.
Possibly just give it a try to make it and paste match. But if I should guess this wont work.
Their might be away to write a lisp file to assist also not sure about it.
Good luck sir https://knowledge.autodesk.com/support/autocad/learn-explore/caas/video/youtube/lesson/144465-course...
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Text-i...
Valentin_CAD
@omorah ,
You can copy objects and style information from one drawing to another in DesignCenter.
A simple copy / paste from the Menu Bar > Edit > pulldown may also provide what you need.
Read more in the Autodesk Support:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Kent1Cooper
@omorah wrote:
... I already have an MText of three columned General Notes, but would like to match it to an MText in another drawing. .... Wish an MText settings can be named.
Am I correct that what you are talking about matching [or naming] is the three-columned format, presumably with column widths and gutter widths and so on?  If so, I don't know of a way, but in any case the replies about Text Styles are not relevant.
But you could Copy/Paste the formatted one into the drawing with the unformatted one, delete all the text content from the one you brought in, and Copy/Paste the text content out of the unformatted one into the emptied formatted one, then get rid of the old unformatted one.
Kent Cooper, AIA
