Data link table
Data link table
janakaL6JKK
Message 1 of 17
Data link table
janakaL6JKK
Hi All,
Can anyone please help me with this?
In the screenshot, generated tables using the same excel through data link on my computer and another computer, but my computer appears as small text and table size also mismatch. I have checked with fonts, table styles any many ways, but I can't sort out this.
Replies (16)
Message 2 of 17
cheryl.buck
Autodesk Support
Autodesk Support
Hi @janakaL6JKK,
That is unexpected. It kind of looks like an import setting could be affecting the scale.  Can you check the Datalink Import settings are the same on both computers, as shown in this post?
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 3 of 17
tony1978
Hi there. Just curious have you tried using the .xlsx file when you are in Excel? That's is the file format that I use when I Import drainage area maps, and hydraulic tables. I dont use the .csv file format
Please click Accept Solutions if this worked for you. Thank you
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
Message 4 of 17
janakaL6JKK
I'm using excel with the *.xlsx file for the data link. Not use *.cvs.
Message 5 of 17
janakaL6JKK
As post you have the tag, I can't access the text height of the tables (as per attached).
Message 6 of 17
tony1978
Most likely the cells are locked. Select the first cell on the upper left and hold down the shift key and select the last cell at the lower left corner. Then on the ribbon under format, there is pull down under Cell Locking, select unlocked. This will allow you to change all the cell heights at one time.
 Tony Carcamo
President/Owner
Message 7 of 17
tony1978
let me know if this worked,
 Tony Carcamo
President/Owner
Message 8 of 17
janakaL6JKK
Thank you for the reply.
I don't need to do this manually.
I need to fix this issue to match the same table properties to other computers.
Message 9 of 17
tony1978
hmmm like a preset setting? I will say that when i bring in the data link it works just fine 95% of the time. The other 5% of times one or two are the wrong size so I have to manually change it back. I honestly dont know what causes for one or two cells to not work properly.  I will have to look to see when you insert the table it can be set to unlock all set as a default.
 Tony Carcamo
President/Owner
Message 10 of 17
janakaL6JKK
I have used this table as many drawings for few years without any problem.
But on this new laptop (I hope) I got this error.
Message 11 of 17
tony1978
possible another option for you is to use the Insert Ole object and linked it to the spread sheet.
 Tony Carcamo
President/Owner
Message 12 of 17
tony1978
this options will give you an notification if the spreadsheet has been updated.
 Tony Carcamo
President/Owner
Message 13 of 17
tony1978
on your new laptop are you pointing to a company font folder under the Options/File tab?
 Tony Carcamo
President/Owner
Message 14 of 17
janakaL6JKK
No, how can I do that?
Message 15 of 17
janakaL6JKK
I have re-installed it, but the same result.
Message 16 of 17
Valentin_CAD
@janakaL6JKK ,
To insert consistently sized tables, uncheck Use Excel Formatting for new data links.
Also consider this other link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 17 of 17
janakaL6JKK
Alternatively, a cell style can be made from the original table and the new table can be matched to it:
  1. Click a cell in an existing table.
  2. Right-click > Cell Style > Create new style from cell.
  3. Name and save it.
  4. Click in the new table.
  5. Select all the cells.
  6. Right-click > Cell Style and pick the style.
This works well when the smaller cells are sizing up to fit the larger text style
This method works well, but the thing is I have to do this for each and every drawing by da today and It's very difficult.
