Can anyone help, I'm looking for a recommendation for a symbol library for P&ID symbols, pipelines, electrical, etc. for ACAD 16. Something for my company to purchase, not Johnny's weekend freeware version. I realise this isn't your typical kind of fixit post, but it would certainly help me fix a whole bunch of vavariation.
Any suggestions...?
Thanks!
Mark
Solved by john.vellek. Go to Solution.
Hi @MarkFitz,
Have you checked the Autodesk App Store to see what kind of content might be available?
You might also try a Trial of AutoCAD P&ID or Plant 3D
Hi Mark,
Did you get any resolution to this question in your other thread?
Hi Mark,
Thanks for the update. Have you had the chance to give a trial a run on your side? I suggest that if you do decide to go to an AutoCAD vertical that you look at AutoCAD Plant 3D. While it might feel like overkill at first, I think long-term that is probably the best solution.
