Hi all,
I have to reformat an existing drawing to match layer properties from a provided template drawing. Unfortunately there are a number of existing layers with the same names as the layers I would like to import and when I add the template layers through design center it does not change the properties of the pre-existing layers with the same names. Is there anyway to get imported layers to override existing layer properties?
A few notes:
- There are objects on the existing layers so they can't be deleted
- There are a large number of layers so manually updating the properties of each of the "problem" layers would ideally be a last resort
Thanks!
