Overwrite existing/duplicate layer properties when adding layers through design center?
prowse_n
prowse_n
Hi all,
I have to reformat an existing drawing to match layer properties from a provided template drawing. Unfortunately there are a number of existing layers with the same names as the layers I would like to import and when I add the template layers through design center it does not change the properties of the pre-existing layers with the same names. Is there anyway to get imported layers to override existing layer properties?
A few notes:
- There are objects on the existing layers so they can't be deleted
- There are a large number of layers so manually updating the properties of each of the "problem" layers would ideally be a last resort
Thanks!
paullimapa
What if you insert your drawing exploded into the template file?
Paul Li
IT Specialist
@The Office
cadffm
Commands STANDARDS
and LAYTRANS can help to do this.
Or you can set up a simple command script (if you are not trained to create scripts, it needs a lot of time, otherwise 10min)
Sebastian
prowse_n
Thank you, STANDARDS seems to do the trick! Do you know if there's a way to ignore the "non-standard name" problem? There are non-standard layers which I will move objects from, but want to only review the non-standard properties at this moment.
Update: I was able to create a copy of the standard with all additional layers and styles added, so it was only the non-standard layer properties that were flagged.
