Overriding the HPLAYER value in a custom hatch tool
Hi there, a little help on this matter much appreciated.
I am setting up a CAD standard dwg file at the office, and I have created a tool palette with some custom hatches.
Each tool inserts its hatch pattern onto a specific layer (e.g concrete hatch on A-PATT_CONC, blockwork hatch on A-PATT_BLOK, etc....)
I set HPLAYER to A-PATT so that every new hatch created in the file will automatically go to that layer (trying to avoid hatches on wrong layers!)
The problem i am now facing is that the new HPLAYER value is overriding my hatches in the tool palette, and any hatch created from the tool palette is automatically going to A-PATT regardless of the layer setting in each tool.
Is there any way to get my hatch tools to ignore/override the HPLAYER value? I tried using layer keys but it seems hathces are not AEC objects.
john.vellek
Hi @Anonymous,
Here is the way I set up my hatch layers for patterns that I put on Tool Palettes. I select the Hatch on the Palette, Rt-click and select Properties.In the list of properties I can set the layer to an existing layer in the drawing. I also have options to pre-select other properties of the hatch to be inserted.
I hope this answers your question.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Good morning yasmineabboud,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
