- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to clean up a file with 400k objects with overkill but it does not work as intended. It does not recognize some objects that seem like exact duplicates to me. I extracted 2 such objects and attached here.
I've tried the following steps:
1. Run overkill with tolerance 0 and all boxes unchecked
2. Tolerance 1, boxes off
3. Tolerance 0, "ignore object property boxes" checked, "option" boxes unchecked
4-8. Tolerance 0, "ignore object property boxes" unchecked, "option" boxes checked one-by-one
The above steps do not work.
Steps that do work:
9. The checkbox combo that does delete duplicate lines but overall does a poor job because it breaks the polyline is "optimize segments within polylines" and "combine colinear objects that partially overlap".
10. Also, if I explode polylines, then run overkill, it does delete duplicates as it should.
But I want to keep polylines.
I can't figure out what's wrong with these objects.
