Message 1 of 8
Overkill Delete Order
- Mute
- Permalink
- Report
What is the delete order for the overkill command? If there are two objects that are identical except the layer, which object will be deleted if the layer property is set to be ignored?
I would like to be able to know which one will be deleted so I can control the outcome. I have attributed blocks that I have imported from excel that I would like to be set apart either by color or layer. The find and replace is too slow to use for object selection.
