Osnap perpendicular from previous command is ridiculous
mjohnson3MF66
Message 1 of 51
mjohnson3MF66
A perpendicular snap is perfectly fine, IF it has to do with the current object I am drawing.
Say, if I'm in the middle of drawing a line and a common snap point for lines would be perpendicular to another object, GREAT.
BUT, now say I draw a circle at one point, finish the command, then invoke a new circle command, and try to draw a circle somewhere else. When I do that, and the new circle keeps trying to snap to a point perpendicular from the center of the FIRST circle, this is NOT OK!
How do I keep my perpendicular snap turned on, but keep it from snapping to ridiculous perpendicular points from irrelevant previous commands?
Replies (50)
Message 2 of 51
qnologi
Message 3 of 51
natasha.l
Hello @mjohnson3MF66
You can use the shortcut Ctrl + F3 object snaps to turn it on & off as you work.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 4 of 51
RobDraw
Your irrelevant points are useful for others. There are a number of ways to control your snaps. Temporary overrides and hot keys are just two of them.
Rob
Message 5 of 51
mjohnson3MF66
I don't remember asking if it was good for somebody else. I know I can turn osnap on and off.
The question is, how do I keep osnap ON, and keep it associating with only the current command?
When I start a NEW command, it's not because I want PAST commands to have anything to do with it.
Message 6 of 51
qnologi
Did you try changing your "aperture" size to a lower setting, to see if that helped?
qnologi
Message 7 of 51
pendean
Community Legend
Community Legend
The program doesn't wok like that: you either get in the habit of tapping F3 to toggle off/on your running osnaps, reduce your Aperture size to really small, or you rewrite every command as a LISP and use them instead.
How would you like to proceed?
Message 8 of 51
AllenJessup
I've tried to duplicate your problem in 2020. The only time I get a perpendicular osnap is when I'm actually selecting on the circle radius. This makes me think that the previous comments regarding the Aperture setting may be relevant.
Allen Jessup
CAD Manager - Designer
Message 9 of 51
cadffm
Upload a screencast,
I want to see what you are talking about.
https://knowledge.autodesk.com/de/community/screencast
After viewing the screencast we can not change the program, but perhaps we can help you for a better handling with the cursor/settings.
I always find it amazing how you can be able to work with this program (successful), like me, Rob, pendean an hundredthousand more.
(joke).
Sebastian
Message 10 of 51
Kent1Cooper
@AllenJessup wrote:
I've tried to duplicate your problem in 2020. The only time I get a perpendicular osnap is when I'm actually selecting on the circle radius. ....
I don't think it's ridiculous that it works this way, and I can see why some would prefer that it not do so, but it does  operate as they describe for me, in Acad2019 where I am at the moment.
In the image, I have blips turned on, so you can see the basis of the Circle there; the top line of command history showing is where I picked to specify the radius [the rightward blip].  Then I recalled the command with ENTER, and as you can see from the command line, it's asking for a center point, and with Osnap on with PERpendicular one of the running modes, if I were to pick where the crosshairs are, it would indeed use the point PERpendicular to the Line from the previous Circle's center [not from the last picked point on the Circle perimeter], where the green Osnap PER icon is.  I also have MIDpoint mode running, so if I move the cursor a little farther to the right, the Osnap moves to going for the MIDpoint of the Line.
HOWEVER, I note that while it does this for the center of a Circle, it does not  do it for the start point of a Line, and I can see there being a legitimate complaint about that difference, whichever side of the fence one sits on.  [I haven't tried other commands to see in which this happens.]
I don't think the size of the Osnap Aperture box [visible in the image] would make any difference -- if something Osnappable crosses it, regardless of the box's size, it will Snap to it [or to the nearest of multiple choices].
Kent Cooper, AIA
Message 11 of 51
mjohnson3MF66
Yes, the aperture size didn't help. The points I need to snap to are very close, and they seem to be overridden even when I zoom in. Thanks for the effort qnologi.
Message 12 of 51
AllenJessup
Thanks Kent,
I now CAN duplicate it in 2020 and even know what's happening. But not how to solve it.
For some reason, in only this case, the perpendicular command is taking the value in the LASTANGLE variable and using it as the angle from the from the center of the Circle (most likely) stored in the LASTPOINT variable and using those values to create the perpendicular point.
I don't see why this should be the exception to every other case. I would consider it a BUG. But Autodesk might consider it to be working As Expected.
Allen Jessup
Message 13 of 51
RobDraw
As stated before, there are ways to control your OSnaps so that you can use the desired one. In addition to the two that I mentioned before, you can use the tab key to cycle through your running OSnaps.
Rob
Message 14 of 51
mjohnson3MF66
Thank you Allen.
Here is a screen shot of how it is working for me.
The first shot shows a circle I've drawn which automatically used the "intersection" snap point.
And below it is the "perpendicular" point it's selecting for the new circle under it.
The vertical line is not straight up and down. The bottom end of the line is further to the left.
The next image to the right shows zoomed far in, with the aperture size reduced, and cross hair directly over the intersection.
It still wants to select the perpendicular point to the right.
Message 15 of 51
RobDraw
Tab?
Rob
Message 16 of 51
mjohnson3MF66
No, tab cycles through every snap point except "intersection" and isn't the automatic osnap selection of the closest snap point.
Message 17 of 51
RobDraw
No, tab cycles through every snap point except "intersection".
Yes, if you have intersection selected in your running OSnaps. I suppose it's possible that the lines are not really intersected but that wouldn't happen to you, would it?
Rob
Message 18 of 51
mjohnson3MF66
Nice snarky response once again ROB. Yes I actually have intersection selected ROB.
Do I need to just accept your response as an answer to make you happy?
Message 19 of 51
RobDraw
Nope, you need to figure out why your intersection snap is not working.
Rob
Message 20 of 51
mjohnson3MF66
BINGO
