EXPORTLAYOUT - Lisp file for exporting multiple tabs to separate drawings
keithTZYB5
Message 1 of 13
keithTZYB5
Hi
Where do I get the lisp file noted in the article below - there is no obvious link to it?
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Automati...
Issue:
When using the EXPORTLAYOUT command in AutoCAD, only one layout or paperspace is exported as drawing at a time. How to export multiple layouts to individual DWG files automatically?
Solution:
  • There is no automated routines within AutoCAD but you can load free lisp file using the full version of AutoCAD.
Cheers,
Keith.
Replies (12)
Message 2 of 13
Alfred.NESWADBA
Have you tried to click there (in the article you showed):
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
maratovich
No problem, use this:
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 4 of 13
pendean
Community Legend
Community Legend
Message 5 of 13
keithTZYB5
Hi Alfred,
Yes I did try that link and as it suggests, it is a third party application. I am in a corporate situation and so i cannot load 3rd party stuff.
Cheers
Message 6 of 13
maratovich
Everyone has a choice - a red or blue pill 🙂
www.kdmsoft.net
Message 7 of 13
Alfred.NESWADBA
Well, your question was how to get that app, if you don't want it or you are not allowed to install or to use it, then I don't understand your initial post.
- alfred -
Alfred NESWADBA
Message 8 of 13
S.Faris
Try the attached LISP files
Source :
JTB LayoutsToDwgs - Export layouts to separate drawings - LayoutsToDwgs.lsp (This is the LISP format of the 3rd party app mentioned)
LXA Export Multiple Layouts To DWG Files
SALMANUL FARIS
Message 9 of 13
Alfred.NESWADBA
As the OP wrote he is not allowed to use 3rd party app, I would say he is not allowed to use that too ... but lets see 😉
- alfred -
Alfred NESWADBA
Message 10 of 13
S.Faris
I believe he was looking for the LISP solution mentioned in the AKN article, as he highlighted in the OP (he never pointed to the second 3rd party solution) .but lets see 😉
SALMANUL FARIS
Message 11 of 13
keithTZYB5
Thanks Guys,
I will try the solutions offered but things have moved on and the need is not urgent right now.
I was looking for the lisp that the AKN suggested existed. I was expecting a knowledgeable person to know where to find this but I get the impression t hat it doesn't exist. Hohum. For what it is worth (not much I guess), I feel that the authors of these articles should make a point of providing links to anything the reference (as they did in this case with the 3rd party stuff) and check it actually exists. Then again, I might just be unlucky and these things are normally fully referenced.
Thanks again for your time.
Message 12 of 13
S.Faris
Hi, The LISP file you are looking for is referenced and attached in message MESSAGE 8 OF 11 of this thread. What more are you expecting on this matter?
SALMANUL FARIS
Message 13 of 13
aadish_bin_abdul_sathar
thank you very much 🙂
