>> I am a teacher and I was wondering if there is a
>> way to know who created a drawing
No, often discussed but without having a tool installed which watches the steps the user did and saves this inside the dwg-file there is no guarantee to know it's a plagiarism.
You might have a chance if the user 1 has made a mistake and you'll find a drawing from someone else with the same difference ... and in case you are sure it's not an interpretation thing of the job description.
>> if I could also know the DWG Author, I would be very happy!
You might find some system variables like e.g. ONLINEUSERID, you might be able to compare drawings (with some small program) which looks to the sort of the object creation.
But all that is very easy to manipulate like create a new drawing, use copy & paste to copy geometry from dwg1 to dwg2 or save as DXF and insert that DXF into a new dwg ... and a lot more which makes it impossible to find a proof for "this is a clone from XXX".
What you can do is to create exercises which are individual for each of your students. E.g the wall length = student-id * 0.155 and something like this. Then copy and paste does not work. The only thing which might help here (and at least is how you can control it) to build the complete task based on parameter and so make it easy to create variants.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
