Ortho mode not stay active from file to file
Is there a way to keep ORTHO mode active even when switching between files? It used to be this way in earlier versions of AutoCAD but now I have to switch it in every new file.
Patchy
It saves in the drawing, you have to make a startup for that sysvar.
Did you have in the acaddoc.lsp before?
No, I do not have it.
How do I write into the file?
thanks
Patchy
Save this .lsp to your acad SUPPORT folder.
and restart your Autocad.
TomBeauford
Add this line into your acaddoc.lsp file:
(setvar 'orthomode 1)
F8 toggles ortho as well as working as a temporary override while in a command prompting for a point same as the Shift key.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Thank you.
