Orbit command problem
jfte3d
Message 1 of 8
jfte3d
Using Orbit Command, in parallel mode, all objects disapears when zoom in or out with the mouse. Switching to perspective mode, all objects are back...this problem is new whit the latest Autocad 2017 sp.
Replies (7)
Message 2 of 8
Alfred.NESWADBA
What is your latest service pack? Start command _ABOUT and show us the screenshot so we can see which update you have installed.
For me command _ORBIT works, I have activated the hardware acceleration and tried now with the basic visual style "2D Wireframe" as well as "Conceptual" ==> what environment have you had for testing? And did you test the same with a new drawing, just one box and start the command?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
jfte3d
Thank you Alfred for your time, Yes I tried new drawing as well as existant file...Hardware turned on with all option, turned off. I have a Zbook Studio with a certified card Quadro M1000...It is only when zooming that I lost the objects. Noticed that the target Z goes really far..tried also to enable the auto target (which was create a fatal error in the past). I will try to investigate my mouse wheel...Aslo tried zoomfactor set to 10, 60..Been using Autocad for 20 years, first time I see this.
Message 4 of 8
jfte3d
The version I have is 2017.1.1 Update.
This problem came with the 2017.1, released 1 month ago
Message 5 of 8
Alfred.NESWADBA
I can't reproduce that issue, at least how I understand it ... what am I doing different?
Can you show what happens on your screen (e.g. using free Autodesk Screencast >>>click<<<)
- alfred -
Alfred NESWADBA
Message 6 of 8
jfte3d
Hello, I recorded a Screen cast to show you my issue
thanks again for helping me.
http://autode.sk/2guMwwN
Message 7 of 8
Alfred.NESWADBA
look to your target-Z when you scroll, that's where you have to start investigating about your scene.
- alfred -
Alfred NESWADBA
Message 8 of 8
jfte3d
Thank's again Alfred, there must be something with that Z target...Couldn't find any solution...I will continue to investigate. I will try another mouse, just in case.
