Opening of Layer List
apanbasu
apanbasu
I am running 2019 version.
I am not sure what I did but the Layer list is not opening. It is on the top of the drawing in a small window.
I have attached the drawing to show what is exactly happening.
Any guidance to correct the problem will be highly appreciated.
Accepted solutions (3)
paullimapa
Posting your dwg files won't show us what you're seeing with the layer window.
Perhaps you can try resetting your Ribbon by entering the command CUI, right mouse click on ACAD and then select Reset ACAD.CUIX
If that fails you can also try Resetting AutoCAD:
How to reset AutoCAD to defaults
Paul Li
IT Specialist
@The Office
imadHabash
As much as i understand your issue....
  • you can get those Layer from upper menu  Tools >> Toolbars >> AutoCAD >> Layers.
  • Also If your ribbon is active, Double click on Home tab to get another Layer control.
  • From upper Quick access toolbar.
Click on below image to see what i mean ....
Hope that help you....
Imad Habash
jreidKVSUZ
Maybe you would like the old school way of showing your layers:
Type in LA first to see how it looks now.
Then after setting the Classic, type LA.
I use Classic for this all the time.
AutoCAD: Using The Classic Layer Dialog Box
The newer versions of AutoCAD now have a new Palette based Layer Dialog (Strating in 2009). This will allow you to change anything and work in the background at the same time. This can be handy but what if you have issues and just want to old Dialog Box back. You can do this using a Variable.
How to turn on the classic Layer dialog
1.) Type LAYERDLGMODE and hit the <Enter> key
2.) Type 0 and hit the <Enter> key
Now your Dialog is set to use the classic version
LAYERDLGMODE = 0  Classic Mode
LAYERDLGMODE = 1  New Palette display
Hope this helps!
JRR!
apanbasu
Thank you all. I just re-install the software and then using Tools/ Pallets - set up the pallets and it is working  now.
Thanks again for the helping hand.
jreidKVSUZ
Just glad you have it working the way you needed it to be!
