PC3 File not found
PC3 File not found
PC3 File not found
Installed AutocadLT2020.  Loaded correctly, works fine.   Went to plot file and keep getting error message
"Update PC3 file with new printer.   Dont have a new printer/plotter.   error message says "the device specified in the PC3 file can not be found.   Go select my plotter, then it spits it back to same error message.... over and over.
Need an answer.  Cant plot a single thing!!!
ennujozlagam
you can refer to these LINK and LINK and see if helps. thanks
pendean
Community Legend
Community Legend
Are you trying to use an old PC3 file from an old version or one from another PC? PC3 files are like traffic signs, they work in the right spot but move them and they stop working as they point to the wrong spot.
littlechrisl
Community Visitor
Community Visitor
SELECT "NONE" to break out of the cycle
