AutoCAD Forum
Open Inventor .IV import
4 REPLIES 4
2388 Views, 4 Replies
Is there a way to import .iv files into Autocad or Revit?
4 REPLIES 4
BeKirra
BeKirra
Which AutoCAD version do you have?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
JDMather
in reply to: BeKirra
JDMather
I do not see a *.iv file type in that list.
BeKirra
in reply to: JDMather
BeKirra
I learned this - *.iv file is not an Inventor file format.
And the title of this thread is a little bit confused to autocad/inventor users. Smiley Sad
Actually the *.iv file is opened by "Open Inventor", a non autodesk program.
X² + Y² = C²
X² + Y² = C²
That is correct. A .iv file belongs to "open inventor" a non-autodesk product. From what I've found the only program that allows a direct import is Maya. I'm trying to find a way to possibly convert the file time to something that AutoCad or Revit will accept.
AutoCAD Inside the Factory
