AutoCAD Forum
Open drawing with CTRL-N
5 REPLIES 5
Rikkes
972 Views, 5 Replies
I would like to open a specified drawing when I push CTRL-N.
The drawing that I would like to open with this command is located on our serven at adress \\SERVERBOOM\DataBoom\BOOM\Jobs\ACad Sjablonen\Rikkes\Start.dwg.
Now in the CUI, I changed the CTRL-N command to this ^C^C_open;"\\SERVERBOOM\DataBoom\BOOM\Jobs\ACad Sjablonen\Rikkes\Start.dwg";^C^C but that doesn't work.
Where did I go wrong?
Thx
Rikkes
5 REPLIES 5
Jonathan3891
in reply to: Rikkes
Try this:
^C^C(startapp "explorer" (findfile "//SERVERBOOM/DataBoom/BOOM/Jobs/ACad Sjablonen/Rikkes/Start.dwg"))
If "SERVERBOOM" has been mapped on your machine is will have a letter associated with it. Use that inplace of //SERVERBOOM.
For example if it were called your "I" drive
^C^C(startapp "explorer" (findfile "I:/DataBoom/BOOM/Jobs/ACad Sjablonen/Rikkes/Start.dwg"))
Jonathan Norton
Blog | Linkedin
steve216586
in reply to: Jonathan3891
You just gave this guy the code to detonate explosives remotely through his AutoCad!  😛
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Rikkes
in reply to: steve216586
Steve, what do you mean by this? Is it a problem to use that code?
Jonathan3891
in reply to: Rikkes
He's just kidding, notice the silly face.
I use this method to launch excel files and other programs from AutoCAD frequently.
Jonathan Norton
Blog | Linkedin
Rikkes
Yes, I tought also but you never know... 🙂
Anyway , it works fine! Thx!
Rikkes
AutoCAD Inside the Factory
