I would like to open a specified drawing when I push CTRL-N.
The drawing that I would like to open with this command is located on our serven at adress \\SERVERBOOM\DataBoom\BOOM\Jobs\ACad Sjablonen\Rikkes\Start.dwg.
Now in the CUI, I changed the CTRL-N command to this ^C^C_open;"\\SERVERBOOM\DataBoom\BOOM\Jobs\ACad Sjablonen\Rikkes\Start.dwg";^C^C but that doesn't work.
Where did I go wrong?
Thx
Rikkes
Solved by Jonathan3891. Go to Solution.
Try this:
^C^C(startapp "explorer" (findfile "//SERVERBOOM/DataBoom/BOOM/Jobs/ACad Sjablonen/Rikkes/Start.dwg"))
If "SERVERBOOM" has been mapped on your machine is will have a letter associated with it. Use that inplace of //SERVERBOOM.
For example if it were called your "I" drive
^C^C(startapp "explorer" (findfile "I:/DataBoom/BOOM/Jobs/ACad Sjablonen/Rikkes/Start.dwg"))
You just gave this guy the code to detonate explosives remotely through his AutoCad! 😛
Yes, I tought also but you never know... 🙂
Anyway , it works fine! Thx!
Rikkes
