Open AI File in Autocad
Hi I'm having trouble converting an adobe illustrator file (attached) to dwg format and opening with autocad.  Can anyone help?
imadHabash
Hi and Welcome to AutoCAD Forum,
I suggest to read this AKN article that may help >> Click << and to to follow this successfully attempts >> Click << .
Imad Habash
R_Tweed
I converted the file to a pdf.
Thanks, but is it possible to convert it to a dwg or dxf file - or not?
vinodkl
Hi @Anonymous ,
Yes. A pdf can be imported into AutoCAD which will be imported as AutoCAD entities using the command "PDFIMPORT". I have imported the PDF into the drawing and attached it here. See if this helps🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
