AutoCAD Forum
Surface "extruding" with z axis only
2 REPLIES 2
BB8x
756 Views, 2 Replies
Hello
I have surface made from many planar surface.Lets say it is the top. I would like to copy this surface below for lets say 2 metres - orto Z only.
How to create solid from this surface entering height 2 metres? Extruding does not work - it is not keep z axis. Thinker has issue as it intersects
Any idea how to?
2 REPLIES 2
vladimir_michl
in reply to: BB8x
Can you just copy the surface using an offset of 0,0,-2 and then use a difference volume? See:
https://www.cadforum.cz/cadforum_en/difference-volume-3d-solid-between-two-tin-surfaces-sets-tip1105...
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
BB8x
in reply to: BB8x
My knowledge is bit better - extrude/select axis Z
AutoCAD Inside the Factory
